Windows 10.0.19044 SR0.0 or greater (Physical RAM: 16Gb)
Primary display and OpenGL: NVIDIA GeForce RTX 2070 Super with Max-Q Design (NVidia) Memory: 8GB, Driver date: 12-29-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 511.09
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 1-22-2020 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-29-2021
Driver Version: 30.0.15.1109
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
That was a dead end, one thing i did notice that if i used a different Units in the file (Decimal Feet for instance) I lose the view, in millimeters everything is fine.
To elaborate, create a fresh file in MM, add your DWG file and i have no issues.
I had also issues with dissapearing geometry,when I recall correctly it was the some plane componentor with a plane input(like mirror). You maybe could backtrack it by deleting them to see if the geo appears
I have a Grasshopper definition to add panel thickness to planar climbing wall surfaces.
Until very shortly I’ve been using the cosine of the angle of adjacent surfaces to get the mitres right.
The cosine of a 90° angle is 0.
Dividing my panel thickness of 21 mm by the cosine results in the length of the mitre.
21 divided by 0 results in an infinite number… 342967353296061000.00 to be exact…
Long story short, if there is a 90° angle somewhere, I have an extrusion with an infinite amplitude and all my geometry disappears from my perspective viewport.
I have found a better solution in the meantime and I’m not interested in any workarounds. The purpose of this post is solely to explain a possible cause of geometry disappearing in the perspective viewport…
It’s been brought to my attention that line/plane intersection has been reported to cause this in rare cases as well. So down to a large value being created or line/plane component.
In the example below, disabling the division by 0 component shows the GH geometry. However the problem is actually what happens with the big number resulting in the division by 0. The division by 0 can remain enabled. It’s the extrusion and the translation which cause the geometry to disappear. Selecting the problematic component shows the geometry outline selected again. At least the extrusion component has this behavior…
This is definitely a bug…I encountered this situation several times all happened in a sudden. The script worked fine, and unexpected disappearance of all my geometries in perspective view. No even involved a divide-zero operation in my script.
Happened to me as well. Attached here is my GH-file, where the culprit is an ‘Offset on Srf’ module.
As soon as I enable it, the perspective view fails to render.
@Janis_Petke looking at your definition I noticed you projected a curve onto the brep and created a ruled surface to split the brep and I think that’s problematic. The ruled surface wraps around the corner. This is causing problems later on and in my opinion it is not a Grasshopper bug.
I agree on your solution. My original file was something quite quick and dirty. Still, the developers should look into the bug inside grasshopper causing geometry in Rhino to dissappear.
But luckily, cleaning up the grasshopper code like you showed, helps!
