Generating Gridshell
Hello everyone!
I’m looking for some help generating a gridshell from a mesh surface. To give you an idea of what I’m aiming for, here’s my inspiration – I’d like to wrap it around an existing massing:
Here’s the mesh I have, which came from a Kangaroo simulation:
And this is the kind of gridshell I’d like to create, but I haven’t figured out how:
I’m using the “Stripper” plugin to sort the mesh faces into horizontal and vertical strips, which might be helpful:
Any guidance or suggestions on how to generate this gridshell would be greatly appreciated.
Thank you!
Gridshell Question.gh (23.3 KB)
Would Paneling tools help? Paneling tools gives a logical index across the faces also.
https://www.food4rhino.com/en/app/panelingtools-rhino-and-grasshopper
Hello Scott, thank you for your suggestion. Generating the pattern I’m looking for would definitely be more straightforward on a surface-based massing. I’ve even found tutorials that demonstrate that approach successfully:
Unfortunately, my massing can’t be a surface because it’s a mesh derived from a SubD multipipe. Since a surface is fundamentally 2D geometry defined by a U and V grid, paneling works better on surfaces, but that option isn’t available to me.
I wonder if there’s a way to apply a similar approach to a sorted mesh. Do you have any thoughts on this?
