Is it possible to generate Sub-D from Grasshopper which can be edited in Rhino 7 as native Sub-D from Rhino? IF yes do you have an example of Grasshopper definition?
There is a Sub-D From Mesh component which you can make your Sub-D in Grasshopper. Then just bake the Sub-D into Rhino and edit it in Rhino as needed.
Thank you very much !
And how to bake the subd and obtain a subd in Rhino?
The same way you bake anything else.
