I believe there is a command to generate iso curves automatically and set a number of how many you want across a surface. I don’t remember it’s name…help!
TIA
Paul
TIA
Paul
Rebuild
Hi Paul,
I only know of ExtractIsocurve and ExtractWireframe but neither of these will let you set a number in-command. You will have to change the number of isocurves in the object’s properties first.
HTH…
Thanks, both of you!
Paul
It was just what I needed.
In properties -isovcrve density- you can set the number of isocurves
