I’m working on a portfolio piece: a kitchen scale shaped like a large scoop, so you can weigh things quickly. I want the surface between the bowl and the handle to be as close to Class A as possible, meaning at least G2 (curvature continuous) with clean flow and no visible break in Zebra.
The bowl is wide and deep, and the handle is thin and narrow. In the top view, the outline narrows with concave curves. In the side view, the bottom of the bowl sweeps up in an S-curve to the handle. I attached my sketch with the top and side views.
I’m on Rhino 9 (9.0.26300.09402) for Mac and have tried the following, but I never get a clean result:
BlendSrf as one continuous surface
BlendSrf split into several surfaces
Loft + MatchSrf
EdgeSrf + MatchSrf
NetworkSrf
Patch
Two separate solids + FilletEdge
My question: What is the recommended workflow to connect a wide, deep bowl edge to a thin handle edge with a surface that is G2 at both ends and has no twisting? Specifically, should I build intermediate cross-section curves (for example with Crv2View from the top and side silhouettes) and use Sweep2 or Loft, or is there a better way to prepare the input edges so that BlendSrf or MatchSrf works cleanly?
I’ve attached a reduced .3dm file with only the two parts and the edge curves. Thanks a lot for any help!
There’s still a bit to fix but is a really good solution for production.
I used BlendCrv to make the horizontal (in the image) curve connections, then EdgeSrf to create a clean Deg5 surface.
After you need to MatchSrf multiple time to tweak the control point, of course for the best result you may move manually the points.
To improve the continuity I’ve also used the AddKnot, automatic (you see I’ve 2 more span in my surface.)
this is possible with untrimmed surfaces only.
they give better results for the next hierarchy of surfaces
for the transition planar to planar (twice, mirrored once)
_loft from edge to edge
_matchSrf
for the remaining double-corner-S-like (points are on) (once, mirrored once)
_edgeSrf
_matchSrf (twice)
Well, @Tom_P showed you already how to do it; dead simple. Mind you, when you’re designing consumer products, you may want to consider the “Apple G2 corner”, and change your corner curves for your surfaces accordingly, in order to mimic the formal aesthetics of an arc fillet with a smoother visual acceleration distribution, see example on the left. Enable Record History before using BlendCrv, because then you can retroactively change it with the Edit option.
Thank you so much for your tutorial. I tried it myself using your method, and I’d say I’m pretty close to your solution. You said you only had to apply MatchSRF twice for this part. I’ve tried it several times, and this is my solution. It’s not perfect, but I think it should be good enough for my portfolio. If you’d like to correct my solution, I’ve uploaded the file. And I’d appreciate it if you could give me some feedback on my solution.
You’ll need to render or, if possible, CNC-machine the part to assess the formal aesthetic difference of the various G1 and G2 corner typologies. Then you can make a final decision. It’s all about attention to detail. Ideally, good industrial design educations or higher-tier brands keep physical important formal aesthetic exemplars to look at.
