I was working in G2 just fine and I closed out the program and reopened it and now I can’t seem to open the GH file I was building in.
Here is the error message I am getting:
I’m not sure what to make of it and can’t find an answer online.
Any help is greatly appreciated! At this point I’m figuring my work is lost but I am hoping that’s not the case.
I was using the read from excel node for GH1 (From TT Toolbox) to read a locally stored excel file and get some data. It appeared to be working fine in the graph but not sure if this could be causing the issue?
I managed to reproduce the error again with new files from scratch. I have attached the GH2 files of the last saved version that I can open successfully (suffixed _03a.ghz) and the newer version of the script that I cannot. (suffixed _03d.ghz)
I believe after version 03a I must have done something that corrupted the file and as I continued to save new versions up to 03d I was carrying that corruption with me into each new file save as.
I have now added in all the previous logic I had and although I’ve managed to crash and freeze it I have not corrupted the file and can still open it just fine.
Thank you for your help! I know this is in Alpha but I want to make sure I am not doing something that is consistently breaking the program if I can avoid it!
