Hi.
As I’m rendering some files, I’m noticing a fuzzy haze around the entire object if the object has depth on it. I’m trying to figure out how to get rid of this haze or if it might just be because the computer I’m using is low spec (like, it shouldn’t be used for rendering, but I don’t have access to my normal computer atm).
I’ve turned shadows off to ensure that it isn’t some odd shadow effect. There was no chance, haze is still there.
In the below image, I’ve drawn a box > created surface > ExtrudedSrf > select the outline > 3mm. The colors are basic and changing them or the type doesn’t change anything.
Any help is appreciated.
