Furniture part disappearing
When I change furniture dimensions after placing it into my model, parts of the furniture disappear. Tested on wardrobe and rectangular table. Updating the VA elements sometimes fixes the the issue and sometimes not.
furniture parts disapearing.3dm (5.0 MB)
Hi @Jakub_Sladecek Thanks for reporting this problem. I can reproduce it with your file in my machine as well. However, if I start a new document from a VisualARQ-millimeters template, the Wardrobe and other Furniture styles are generated properly. Can you check this on your side, just in case it is a file-specific issue?
We will investigate what’s happening in any case, and keep you posted!
Hi Francesc,
I get the same result (disappearing door) when I start a new document from a VisualARQ-millimeters and VisualARQ-centimeters template. However, when I start a new document from a VisualARQ-meters template, everything (tested on wardrobe and table style) works fine.
Hi Jakub,
I could reproduce this error also in a VisualARQ-cm template. We will investigate what’s happening and find a solution.
