I comfirm this bug. Also got problems that they are corrupt when moved or changed dimensions. I have to add new one. I also found out, that this is not happening when working in “meters” VA template. Only in mm template. And also when start project in meters, then try to make some cabinets, change units of file to milimeters, it starts to do this bug again.
Would be great if VA team could solve this, it is time consuming to make cabinets new onw everytime trying to change position or size…
I think that doesnt matter the version. I tried in 3.10, 3.11, 3.12…always the same.
I am on Windows 11 and it works in meters, when I set up milimeters it brokes the objects…It could be some problem with units conversion, when calculating sizes in script or GH on background. I think it shoulndt be so hard to debug for VA team, as it starts exactly when switchinig units to mm. Some objects work, some are corrupted with missing sides, drawers, some miss almost everything except few parts.
Hi @Jens_Jacob_Melhus_J1@TwinPlan_MDa@ng5_Alex , the Grasshopper definitions used for some of the Furniture and Element styles in VisualARQ templates are not right. They were created in Rhino 7, and due to an error in one Grasshopper component that is present in several definitions, (that was fixed in an intermedium SR in Rhino 8), there was no evidence of this issue when we tested it initially. (This issue is not noticeable in VisualARQ 3 for Rhino 7).
So the solution for this is to redo the VisualARQ templates, which is something in progress.
If you are using a document in meters, you can just import the styles with the fixed Grasshopper scripts in the .val attached:
