I mostly use the full screen command when I want to render my scene. The problem with Rhino 8 going into Fullscreen is that after few second it freezes, I can’t roll, or pan, or select objects, Nothing, it freezes. The good thing is that Pressing the Esc key multiple times, Rhino unfreezes and exits the Fullscreen. The selected window layout used to change upon exiting Fullscreen and rhino messes up the layout of the arranged toolbars… Now, in version 8.4 and up, the Messing of the user interface layout has been solved, BUT, the Freeze issue Remains, it always happens after few seconds. Can this be addressed and solved: this doesn’t and never happened in Rhino 7
Hi Joe -
I can’t reproduce this behavior on my system. Please run the Rhino SystemInfo command and copy-paste the result here.
Hi Wim,
I tried it now, it freezes after you run the Render Command, and render something, anything. when render finishes, close the render window, back to the full screen, try to pan, or roll, or select objets, Nothing, Rhino is freezed, you must press the Esc key to exit the full screen and unfreezes.
and here is the SystemInfo:
Rhino 8 SR6 2024-4-10 (Rhino 8, 8.6.24101.05001, Git hash:master @ 32c244aa711e0034e75bec2e87d093c764820b96)
License type: Commercial, build 2024-04-10
License details: Stand-Alone
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 16GB)
.NET Framework 4.8.9232.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GTX 1050 Ti (NVidia) Memory: 4GB, Driver date: 4-2-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.12
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-2-2024
Driver Version: 31.0.15.5212
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
Hi Joe -
That still doesn’t happen here. Please also post the rest of the SystemInfo data.
I encountered the same problem!
That’s my situation:
- after working in Rhino8 for a period of time (maybe 0.5 - 1 hour, I didn’t time it )
- run command “fullscreen”, it’s working fine so far
- use middle mouse button to popup my custom toolbar without running any command after.Fullscreen Freeze now!
Here is my SystemInfo:
Rhino 8 SR7 2024-5-13 (Rhino 8, 8.7.24134.03001, Git hash:master @ 215e2aecc0d8fbc7e0448df10b8ce818dac77137)
License type: 商业版, build 2024-05-13
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.0
Primary display and OpenGL: NVIDIA GeForce GTX 1050 Ti (NVidia) Memory: 4GB, Driver date: 4-11-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.22
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 4-11-2024
Driver Version: 31.0.15.5222
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Bongo 2.0 (64-bit)\Rhino6\Bongo.20.rhp “Bongo 2.0”
C:\Program Files\Rhino 8\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.7.24134.3001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.7.24134.3001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.7.24134.3001
C:\Users\admin\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.7.24134.3001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.7.24134.3001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.7.24134.3001
C:\Program Files\Rhino 8\Plug-ins\NamedPositions.rhp “Named Position”
No Solution yet. Rhino freezes in Fullscreen after executing one command. when done, rhino freezes, the good thing is that you press the esc key couple of times, rhino exists the Fullscreen. Don’t worry it never messes your work, you can continue working. it is just a nuisance, an inconvenience, but it is an issue they, a McNeel must resolve in future service releases, hopefully!
I have exactly the same issue with R8
I have a 13th Gen Intel Core i9-13900H, 2600 Mhz, 14 core, 20 proc., with Invidia RTX 4060
it freeze when I make a printscreen if in: ‘rendered’ view mode + fullscreen
ESC+repeat is fine save, but not a solution
