Title speaks for itself. Perspective of the site:
Perspective aligned so that X is right and Z is up:
And then Front View:
No clipping planes exist.
Very frustrating.
can you share the file ?
some ideas to maybe fix it:
what happens if you reset to 4 default viewports ?
(right mouse, sometimes you need to click it twice - at least on the mac version)
what happens if you use the perspektive viewport, make sure cplane is top, then use command plan to get orthographic / parallel view on cplane ( which is more or less a reconstruction of default top )
copy paste data (point clouds) to a new file based on a template ?
kind regards -tom
Thanks Tom! Resetting the viewport layouts worked. I wonder what when wrong in the first place???
… well this is subject to rhinoceros-criminology
maybe some hidden inhabitants in the zoo ?
at least it s nice to have a solution - even if the course of events is not clear -
i would guess some strange camera-settings …
(you may want to mark the solution (checkbox under the post), so other users don t need to dig into the topic)
kind regards - tom
