Frequent Crashes/Shutdowns with Rhino 7 and D5 Render
I am a Rhino 7 user, and I am experiencing extremely frequent crashes whenever I work with D5 Render open. The shutdowns occur even when I am not performing any complex or heavy tasks.
I am certain that this is not a hardware specification issue, as my CPU, RAM, and Graphics Card utilization all remain under 30% when the crashes happen.
Could you please explain why this is happening and how I can resolve this issue? Thank you.
How about when you don’t have D5 open? If you still get crashes with D5 not running, then how about when the D5 installation is entirely removed? If it still crashes, then perhaps the Rhino installation should be repaired or removed and reinstalled. This process will clearly discern whether the issue resides with Rhino, D5 or the D5 integration with Rhino..
Run SystemInfo in Rhino and post the results.
Here is my SYSTEM INFORMATION.
Rhino 7 SR38 2024-12-3 (Rhino 7, 7.38.24338.17001, Git hash:master @ 97e36efa02d7f71638988290bb2d190fcf1b18c5)
License type: Educational, 빌드 2024-12-03
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 63Gb)
Computer platform: DESKTOP
Primary display: AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 9-25-2025 (M-D-Y).
Accelerated graphics device with 5 adapter port(s)
  • Windows Main Display attached to adapter port #0
    Primary OpenGL: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 10-29-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 581.80
Accelerated graphics device with 4 adapter port(s)
  • There are no monitors attached to this device!
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-29-2025
Driver Version: 32.0.15.8180
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\Users\user\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.22258.1121
C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\D5LiveSync (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\D5Conv.rhp “D5 Live Sync for Rhino”
C:\Program Files\Chaos\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “웹브라우저”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “유휴_프로세서”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “레거시 Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “알림”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.38.24338.17001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.38.24338.17001
I would now suggest that you first make the Nviidia RTX 3060 your primary OpenGL card after updating its driver to the latest from Nvidia and switching your monitor to the Nvidia. It probably wouldn’t hurt to check whether the Intel driver is the latest available for that card as well.
If the problem still persists you could then start the diagnostics suggested in my first post.
Another thought is whether a D5 installation somehow conflicts with a V-ray installation.
