is there a setting in Flamingo nXt to show the rendering frame in the perspective viewport, my customer say so, but I don’t find it, there are just the general render frame settings.
Rendering Safe Frame doesn’t react to the Flamingo nXt resolution here, when I set e.g. Flamingos nXt resolution to 400 x 400 pixel, do I see this in the perspective viewport. I think, that’s what the customer want.
Yes, but I don’t see the relation to the Flamingo nXt resolution.safe frame seams like an indepent setting, with no relation to the active render resolution of Flamingo nXt. Or, have I missed something?
The Safe Frame is an aspect ratio for the chosen resolution but not a direct representation of the pixel width and height to be rendered. This way you can set an output size that is greater than what the monitor can display. The Safe Frame also fits its height to the viewport so it can often get clipped on the sides. I find a small viewport like below is best and then you can adjust it’s size until the whole Safe Frame is visible.
