SafeFrame Rhino 7
Hi all. It’s time for another round of SafeFrame-discussions. In the last Rhino 7 WIP the functionality of the SafeFrame in the Render-Panel was gone. If changing from 1280x720 (16:9) to 400x800 and then 640x280 (or any other non-standard). The yellow visual representation of the SafeFrame didn’t update.
Has this been solved in the final version/release candidate? It is critical when using a “tight” framing. Also I would prefer that the selected SafeFrame was always visible in the Viewport even if that result in “clipping” of the ViewPort. To use a full ViewPort you can always choose to disable the SafeFrame.
