Hi @dale,
I am on Windows 10 using Rhino 8 SR17 and I switched to system wide dark theme. I can barely see the headlines in the document properties window on the left side, see below:
Is it possible to change this?
Hi @dale,
Hi Daniel -
It’s not supposed to look like that.
If that doesn’t help, please post your SystemInfo data.
Hi @wim,
thank you for your answer. The setting was custom, because I am usually using a different background color. Switching between light and dark on system level changes many colors even it is on custom in Rhino, but it does not change all colors that are necessary to properly display text.
