Hi!
I have created my own font to use in drawings. Attached are two screenshots of
–the properties panel, where kerning works as it should.
–the model space, where it doesn’t. The same happens in layout space.
The font is an .otf file and works as it should in other applications. Font book says no problems were found with the font. What causes this? Help would be much appreciated.
Oskar
wim
(Wim Dekeyser)
February 27, 2025, 5:12pm
2
Hej Oskar -
Oskar Tegnesjö:
What causes this?
We’ll be needing the output from the Rhino SystemInfo on your machine and the .otf file.
Absolutely! However, it says .otf is not a valid file format for submission.
Rhino 8 SR16 2025-2-11 (Rhino 8, 8.16.25042.13002, Git hash:master @ d0f731de6fe2c5fdcad78ad80faf154307815f18)
License type: Educational, build 2025-02-11
License details: Cloud Zoo
Apple macOS Version 15.1 (Build 24B83) (Physical RAM: 64GB)
Mac Model Identifier: MacBookPro18,2
Language: en-SE (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M1 Max
Color LCD (1728 x 1117 @ 120.00Hz)
GPU Vendor: Apple
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswift_Builtin_float.dylib
/usr/lib/swift/libswift_errno.dylib
/usr/lib/swift/libswift_math.dylib
/usr/lib/swift/libswift_signal.dylib
/usr/lib/swift/libswift_stdio.dylib
/usr/lib/swift/libswift_time.dylib
/usr/lib/swift/libswiftsys_time.dylib
/usr/lib/swift/libswiftunistd.dylib
/usr/lib/swift/libswiftDistributed.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftMLCompute.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftSpatial.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftSynchronization.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.16.25042.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.16.25042.13002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.16.25042.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 8.16.25042.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.16.25042.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.16.25042.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.16.25042.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.16.25042.13002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.16.25042.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.16.25042.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.16.25042.1002
/Applications/Rhino 8.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 8.16.25042.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.16.25042.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.16.25042.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.16.25042.13002
Can I email you the file? Thanks. /O
stevebaer
(Steve Baer)
February 27, 2025, 5:26pm
5
Hi Oskar,
Kerning is not recognized/supported in Rhino 8. The Rhino 9 WIP has added support for kerning as an option to annotation styles.
Thank you for the prompt reply. To be clear, is an annotation style what is being applied to the contents of the Text command and would the kerning then override that as an option? I’m not very familiar with the terminology. /O
stevebaer
(Steve Baer)
February 27, 2025, 5:50pm
8
Text and dimensions have annotation styles associated with them that can be adjusted in document settings and optionally overridden on the object properties panel. The following image is from the Rhino 9 WIP and notice that there is a kerning option.
