Text is bigger when printed
I have a problem in printing or I just don’t know how to set it. When I create a text in rhino and set its size up to making a layout, the font size doesn’t change but when I go and print my file the size go bigger and longer and overlaps other text and lines. I hope to resolve this. Thank you in advance for the advice. Please see the attached file for the problem.
NOTE: For now my solution for this is changing the font style but is there another way that you don’t need to change the font style?
Jay
font problem.pdf (90.9 KB)
Hi Jay - could you please post a 3dm file that shows this behavior?
HI Wim,
Thank you for the reply. Please see the attached file. I also attach a pdf file. I think the correct word for my problem is the text stretches sideways. And in Rhino 4 i don’t have this kind of problem. Only in Rhino 6.
Thank you,
Jayson
template 1.3dm (430.8 KB) template 1.pdf (270.4 KB)
Hi Jayson - thank you for those files. We have this issue logged as RH-54669. I have updated the report with information about the font that you use.
For the time being, the workaround is to either use a different font (e.g. Arial) or print to raster instead of vector.
Hi Wim,
Thank you for your time and advice. I will wait for the update.
Jayson
Note that you can follow activity on that issue report by marking it “watched”.
As of now, this is on the 7.x list.
Hi @wim,
Any update on this issue? I did some testing and the issue might be more extreme with Monospaced fonts.
Raster Vector Print.3dm (43.2 KB)
Hi - thanks for testing - I’ve added your comment to the bug item.
As you can see from that report, it is still open and on the 7.x list.
