Does anyone know how to make the solid pattern sit on the curved wall? I tried the morph component but it doesn’t work as I thought. Please help…
Thanks for your script! However what I want to do is to map the scripted 3D geometry instead of curve on the surface like the picture show, any idea?
you can simply boundary surface to the mapped curves and use OFFSET SURFACE component from pufferfish. (continuation of the same previous script)001 2.gh (15.6 KB)
you can also look at altogether a new approach where you randomly orient the created geometry.
