Hello! I want to know how I can flow an image along a surface? I tried “flow along surface” but it doesn’t work. Anybody knows what can I do?
Thanks in advance!
Thanks in advance!
Hi David - It sounds like you just need to apply the image file as a texture in a material for the bendy object. You may want to extract a copy of a surface of the target object and use it as a custom mapping object - I do not know how Vray behaves with custom mapping.
http://docs.mcneel.com/rhino/5/help/en-us/index.htm#properties/texturemapping.htm#ApplyCustomMapping
Hello Pascal. The link is not working. Can you please sent it back to me? Thanks!
Hi David - try right-click on the link and choose ‘open in a new tab’. Any luck?
