Flow along surface but with meshes in grasshopper
Hello everyone, is there a way to transfer a curve projected onto a mesh to its unrolled counterpart (given that the topology is the same) similarly to what “flow along surface” does?
baba.3dm (205.9 KB)
I attached an example file to play with.
Bonus question: if I have a curve that is close to the mesh but not exactly attached to the mesh how do I project it into the actual mesh?
Edit: everything should be done in grasshopper
Thanks Riccardo
I have used this before and it works pretty great. I think it will work for your situation.
For your second question: there is a mesh closest point component. You can use that
Thank you very much I try right away!
