Grasshopper project curves on mesh surface
the grasshopper project component works to project curves onto a brep or surface, not a mesh surface
is there a way to curves project onto a mesh surface?
the mesh surface is a result of a kangaroo application draping a mesh planar surface onto a sphere
Hi @cshea,
Attached is a custom C# component you can use.
Cshea.gh (12.5 KB)
– Dale
Hi Dale
Thanks!!! it works well!!!
wish it was always so straight forward!!!
really appreciate this!!!
This is very cool @dale, Any chance you could make a variant of this to use the pull curve command instead of directional projection? it’d be super handy for a Curve-based SubD thing we are doing.
Thanks!
G
Hi @gustojunk,
How is this?
Gustavo.gh (23.9 KB)
– Dale
Hi @dale, thanks so much. that works great!
Hi, @dale
I’m trying to do the same, but I can’t download the attached file you gave to Cshea.
Can you please help me?
Hi @nrangel91, You should be able to download that file now.
Let us know if that is not the case.
Thanks,
wim
Hi there,
Thank you so much for that C# component! However, I’m having a problem and I’m not sure where it lies:
I modelled a little mesh with Kangaroo and I wanted to project some curves on it. The C# does almost the whole work but somehow not in the central parts:
grafik
I don’t have a clue of why this is happening or what I could do, so any help would be appreciated:)
Projecting lines onto a Kangaroo mesh.gh (14.4 KB)
Thank you so much Dale! Worked perfectly
Hi, thank you so much for this, it works perfectly and fast, really good !
Great, thanks! apprecite it.
Hi Dale,
It works very well
Thank you : )
I had been searching for almost 2 hours for this very solution. Thank you for uploading this. Tremendously helpful!
Cheers!
It is possible the provided script is not keeping original index of curves? I mean, the index of original curves is different from the ones projected.
@dale can you please add a project curve to mesh component to Grasshopper?
It seems strange that this isn’t included already :slight_smile:
Hey @Holo,
I’ve added your wish to the pile.
https://mcneel.myjetbrains.com/youtrack/issue/RH-64440
– Dale
@dale
Excuse me, I can’t see how the command works
A = Curve.ProjectToMesh (curve, mesh, dir, tol);
I have tried other procedures and the results are not the same
Line-Project_2_Mesh.gh (96.2 KB)
Hi Everyone,
Big wish for the “project curve to mesh” and could you add points as well.
I found this, but don’t know how to use it in GH:
Maybe someone can help me in the meantime…
Cheers,
Thomas
See the attached.
ProjectPullToMesh.gh (14.8 KB)
– Dale
