Floor ByOutline - With internal opening
Hi
Something for the wishlist. When generating Floors by Outline the component only accepts one curve per floor. Quite often floor sketches consists of multiple closed curves resulting in openings in the floor. This is not possible it seems, and instead you get multiple overlapping floors.
It could be nice if the AddFloor.ByOutline component could work similar to the “Boundary” components that can take branches of curves.
Thanks
Relevant info…
Conclusion:
There is no way to create an exact copy of a floor with holes using API as in the UI.
There is a workaround to create holes in the floor using openings instead.
As you said it seems that there’s no way to make floors with holes directly
“There is a workaround to create holes in the floor using openings instead” sounds interesting any suggestions of how I can setup a definition starting from the similar python component for the walls opening that already exist
thank you very much!
