Floating containers problem
I believe Command prompt container and all other popup windows and containers have to be shown above rhino window and moved with it when host window is moved.
Now block edit popup window can be shown on another screen which makes it difficult to find it. Moving Rhino window to a half of screen or moving it to another screen leads to a nasty case when command prompt (if it is floating) and other floating containers stay in the original place, separately from host window, which makes them not useful. Especially when you have to work with multiple Rhinos in parallel - then floating container from one Rhino will overlap with floating container from another Rhino and you never can know which is which. I am using Windows.
Hi Yury,
Right now floating containers keep their own screen position on purpose — they don’t follow the main window when you snap it or move it to another monitor, and popups like Block Edit remember where they were last closed. i agree that gets messy fast, especially with multiple Rhinos running.
A few things that help in the meantime:
  1. WindowLayout — save a layout you like and restore it to snap everything back into place in one shot.
  2. Dock the command prompt so it travels with the main window.
  3. If a container gets stranded off-screen, closing and reopening it (or -_ToolbarReset as a last resort) brings things back.
Added a feature request for containers following the host window: RH-97186
