Is it possible to flip the x and Y axis so the Y goes across the bottom of the screen and the X runs up the screen?
fastest method would be to rotate the canvas in the camera settings of your properties panel, it also works when you rotate the cplane with the command cplane and option rotate.
`! _SetView _World _Bottom _Tiltview _Angle 90 '_CPlane _3Point 0,0,0 1,0,0 0,-1,0
Thanks @dn.aur
2 questions:
- Why does Top switch to bottom?
- That only changes it per the view, how do you change it for the whole project?
It’s a right hand coordinate system, where your requested XY combination can only be achieved, if viewed from the bottom.
Save your view?
