Hi Yianni- can you post a file with those curves? What you show for the direction arrows looks correct, if you flip one, I would expect the bad result…?
The arrows are pointing the right way but the resulting surface points inwards. I want it to point outwards, so naturally, I flip the direction of both sections. That’s when I get the twist.
I want to flip surface direction without breaking history, what’s the right way to do it?
The arrows correspond and the surface is valid.
I just want the Srf direction to point the other way.
How do I accomplish this without breaking history?
I hope you don’t tell me to edit (CrvSeam) the input Crvs before I run the command.
So to get it straight, you would:
A: Run the command
B: see the result is opposite of what want
C: Undo
D: Run the command again and flip the arrows (mid command), becasue you now know this will yeild the reult you require.
Is this how you would do it?
