V5,
looked in help section sweep2 rhino v5
cant see data on following.
Should both rails have dir running in same direction ?
should both profiles have dir running in same direction ?
What is good practice or essential to avoid problems later on if not immediate ?
I am altering my sweeps to be as such but wondered if it was necessary.
If I take a rectangle and extrude it to make a solid, then explode and delete one side then DupEdge to sweep2 it, the dir’s are opposite direction for the rails and the profiles, yet it had a surface prior to this.
Is there a command to select two curves and have it make dir same, flipping one if need be ? all in one action rather than select then dir then deselect then select then flip.
Cheers
Steve
