I need for them to remain a group of separate curves.
I can’t use list item to manually select the curves going in opposite directions because the overall form will be interchangeable, and I do not want to have to change the list item every time. 2023.07.25_ForForum_SG.gh (6.7 KB)
Just tried it and unfortunately no… the referenced curve’s vectors were all going the same direction unlike the directions of the curves I posted above. Thanks for the tip anyways.
Hmm Don’t have an answer… You could try finding the negative vector values. then flipping the corresponding curves. Thats the best I have with the time I have. Sorry.
This is a more serious effort to solve the problem as stated, though it would answer many questions if a series of test geometry were provided instead of just one example. This solution could quickly be shown as inadequate with different geometry.
