I am using the flip component to consistently align a bunch of different curves, however, I have run in some weird behavior that I do not understand. See the example.
This set of curve are what I would call ‘aligned’:
It is my understanding that the flip component only consider the vector connecting end points of a polyline. Can any one share light on what is happening here?
Well, of course I am using a guide because in the bigger picture I am not sure if the curves comes already aligned
But, your work-around works! Thanks!
However, it still makes no sense to me. If only the vector connecting end-points counts, then what I use as a guide (line, or polyline) should not make any difference…
