When I start the rendering this is what I get…not sure it’s a good thing. If you zoom into the render panel it says “Abnormal Termination” with great big numbers in the Number of Passes fields…and then goes no further. Any ideas??? Tonight I will try reloading and perhaps a trial run on another file. This file is about 50 megs…
Good call Brian. As I just bought and installed both Rhino 6 and upgraded Flamingo to match, I assume all is up to date. However, you know what they say about assuming so tonight I’ll run the trusty “Check for Updates” to insure I’m up to date. Then I’ll try another file and see what’s up.
Sounds good, if you still have an issue and need to send the file to tech, you can use https://www.rhino3d.com/upload Please put a link to this forum topic in the comments.
