Fixing Invisible Trimmed Surface
invisibleSurface.3dm (74.2 KB)
This trimmed surface is invisible except for its perimeter edge and I cant figure out why. The surface seems fine in NX, and AutoCAD. The surface was imported into Rhino from a step file and perhaps the conversion from step is breaking it.
When trying to fix it, I used untrim KeepTrimObjects=Yes. This gives me curves. Sometimes (seemingly randomly) I can then split the surface with the trim curves and It looks fine. Other times the split fails (on the exact same geometry). The trim curves look fine. The trim curves do however have 5 segments, but after explode I get 9 pieces (very strange).
Does anyone know what’s wrong with the surface? Is there a way that I can repair it programmatically?
Hi Nick,
If you explode the trim curve you get a very short straight section where the control points are in line but not in order.
If you delete that, the remaining pieces are close enough to rejoin without needing to replace the removed part. The trim curve then needs to be pulled onto the surface for the trim to work, after which you have a “normal” surface.
HTH
Jeremy
Ahhh, I see. Its so tiny that I must have missed that little curve. Thanks Jeremy!
