Fix pop up window RenderContent_ContentChanged
Hi there,
I’m relatively new to Rhino and had everything working fine until suddenly I continually get this pop-up (see attached) every time I click on anything within the viewport. If any one has any solutions to stop this from happening please help me ASAP!
Greatly appreciated.
Chris
@pkinnane is the guy you need for this particular case.
Until a fix is ready you should set the current renderer to Rhino Render while creating your model. Does that work better?.
Hi Chris - that error is from the Octane plugin - and should be fixed in the latest TEST release at https://render.otoy.com/forum/viewtopic.php?f=41&t=55093 . You can also resolve it by opening the OctaneRender panel in the Rhino Properties panel.
Paul
Both worked thank you very much! @pkinnane @nathanletwory
