Error messages every time I select the material panel
This happens every time I select the material panel.
unable to load rendered content from files…
-Simon
@dan, didn’t we already fix something similar not so long ago?
@Zsimon-
Sorry about this. I fixed the bug that caused this in a recent build. However, you won’t see the fix until the newer versions of the Render Content are unpacked to your Library.
If you have NOT made significant changes to your default Render Content, please follow these steps to correct this bug:
  1. Update to the latest RhinoBETA.
  2. Quit Rhino if it is open.
  3. Navigate to Finder > Go > Go to Folder…
  4. Go to the folder: ~/Library/Application Support/McNeel/Rhinoceros/6.0/
  5. Finder should open a window at the above location.
  6. Drag the Render Content folder to the Trash.
  7. Launch RhinoBETA. The problem should be solved.
If you have made changes to the default Render Content that you would like to keep, follow steps 1-5 above and only delete those files that are causing Rhino to throw a warning.
Thanks Dan. It seems to work.
-Simon
