Fit Crv between points
I want to move these points along this line to create a new curve that kicks out less. It seems like it should be very easy, but for some reason I can’t manage to do it cleanly. Thanks for the help
Crv 1.gh (8.9 KB)
please internalise the points at the beginning of your definition.
Thanks, i forgot to save the file after i did it.
Sorry
Should work now
PointAtPercentage.gh (10.2 KB)
are you missing above logic ?
2 approaches
top: one general for curves
below: for lines based on the vector stuff…
if you re scripting Line.PointAt uses normalized parameter:
https://developer.rhino3d.com/api/rhinocommon/rhino.geometry.line/pointat
is this what you re after ?
Crv 1_tp.gh (14.5 KB)
slider = 1.0 → same curve
slider = 0.0 → planar
other values … curve inbetween
Yes that is exactly what i needed, thank you!
happy to help - please mark my post as solutions - so others don t need to dig into the topic to just see it s solve - have a nice evening - tom
I was cleaning up the desktop when I found the original file.
Pure Grasshopper:
Fit Crv between points VR 01.gh (22.2 KB)
