Finding triangles connected to every node of a gridshell structure
Hello!
I am working on a double curved grid structure and facing problems calcuating the loads on the vertices.
There is uniformly distributed self loading on the grid so I need the triangles connected to each node. After that I would be able to alculate the loaded Area for the vertices.
Eg.: for the node marked with green I need the area of the 6 connecting triangles (to calculate the yellow area which contributes to the loading of the given vertex).
The structure:
Gridshell_Triangles.gh (7.1 KB)
Thank you!
Gridshell_Triangles.gh (16.6 KB)
There’s not a built in component for this, but it is easy to do with a one line script:
    A = M.Vertices.GetVertexFaces(V);
I’ve also shown in the definition above how you can make the lines into a mesh using Weaverbird, since your file only included the lines. If you already have the mesh you won’t need this step.
Awesome, thank you for your help!
