Filter by Wall Function (Interior/Exterior)
I’m trying to filter interior from exterior walls based on the “Function” parameter. Our wall families use a type parameter that designates Interior/Exterior under Function. When I attempted to use the ‘Get Element Parameter’ component, it does not recognize the “Function” parameter. Is this do to it being a type parameter, rather than an instance parameter? Is there a different way to find a family type parameter?
Yeah, use the inspect element component on the types (right click on inspect - show all parameters)
once you hook a panel into the Construction - Function right click and remove unused parameters from the inspect
Thanks @Rickson
Exactly what I was looking for!
An example of how filtering works is shown here (last image on the section)
https://www.rhino3d.com/inside/revit/beta/guides/revit-walls#reading-type-parameters
