accounts2
(IVExDesign)
January 13, 2025, 11:22am
1
Hey I am trying to create vector plan drawings for a client and I am having a hard time generating quality vector output.
Especially filleted edges seem to display incorrectly, I am attaching screenshots for reference.
If I can’t get proper vector output from 3D, I may have to end up drawing in 2D, which I’d rather not.
Any ideas on how to fix this?
EDIT: The previous images are from a custom version of technical display mode. It seems to look better in Wireframe mode:
I don’t want wireframes in the plans though, and it would also look better if the lines did not have those big dots at the end.
wim
(Wim Dekeyser)
January 13, 2025, 12:58pm
2
Hi -
Please post both the output of the Rhino SystemInfo command and a 3dm file that we can use to troubleshoot this issue.
accounts2
(IVExDesign)
January 13, 2025, 1:09pm
3
Rhino 8 SR13 2024-11-12 (Rhino 8, 8.13.24317.13002, Git hash:master @ ca3666c3ebed2b9567e10930077bfa0884f65db9)
License type: Commercial, build 2024-11-12
License details: Cloud Zoo
Apple macOS Version 13.6.1 (Build 22G313) (Physical RAM: 16GB)
Mac Model Identifier: MacBookPro16,1
Language: en
.NET 7.0.0
Metal GPU Family Apple 0
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Intel UHD Graphics 630 (1536 MB)
AMD Radeon Pro 5500M (4 GB)
Color LCD (1536 x 960 @ 59.00Hz)
BenQ PD2725U (1920 x 1080 @ 60.00Hz)
GPU Vendor: AMD
USB devices
Razer Inc: Razer Kiyo Pro
GenesysLogic: USB2.1 Hub
Apple: composite_device
Apple Inc.: Touch Bar Backlight
Apple Inc.: Touch Bar Display
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple: Headset
Apple Inc.: Ambient Light Sensor
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple T2 Controller
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/usd/libIex.dylib
/usr/lib/usd/libHalf.dylib
/usr/lib/usd/libAlembic.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/usd/libosdCPU.dylib
/usr/lib/usd/libImath.dylib
/usr/lib/usd/libIlmThread.dylib
/usr/lib/usd/libIexMath.dylib
/usr/lib/usd/libtbb.dylib
/usr/lib/usd/libMaterialXCore.dylib
/usr/lib/usd/libMaterialXFormat.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftExtensionKit.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework "Renderer Development Kit" 8.13.24317.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp "Commands" 8.13.24317.13002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp "Snapshots" 8.13.24317.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp "RDK_EtoUI" 8.13.24317.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp "MeshCommands" 8.13.24317.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp "PDF Export" 8.13.24317.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp "Rhino Render" 8.13.24317.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp "RhinoCycles" 8.13.24317.13002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp "SectionTools" 8.13.24317.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp "Displacement" 8.13.24317.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp "PanelingTools" 8.13.24317.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp "IronPython" 8.13.24317.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp "Grasshopper" 8.13.24317.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp "RhinoCodePlugin" 8.13.24317.13002
accounts2
(IVExDesign)
January 13, 2025, 1:12pm
4
accounts2
(IVExDesign)
January 13, 2025, 1:19pm
5
I just realized I didn’t have the latest update installed. I just installed it and now it looks like filleted corners look good in section / clipped views, but not in regular unclipped views.
Screenshot of filleted corners in Top view (not clipped):
The same corner in clipped view:
accounts2
(IVExDesign)
January 15, 2025, 10:36am
6
bumping my own post
Is this a bug? Is this just how it is? Does anyone know a way to fix this or can think of a workaround? @wim have you had a chance to look at my file?
Make2D produces proper outlines but two major drawbacks as far as I can see:
I’ll have to manually update make2D drawings
the additional hassle of having the 2D linework somewhere in model space and having to manage visibility of layers in layout and model space
ClippingDrawings produces nice results and updates dynamically (right?), but then my problem is not with the clipped drawing but with the regular top and side views. I can’t produce those with ClippingDrawings as far as I can tell. Also again I don’t like the 2D drawings floating around in model space, but that’s something I could live with.
