Hi, V5
I need 1.49 fillet rads on the edges shown ( not along base of item) but end up with V shaped holes.
what is best approach ?
(also the other outside edge needs 1.49 but thats easy.)
FilletEdge gaps.3dm (331.2 KB)
Steve
Hi, V5
Steve
something like the attached is how I would do it
FilletEdge gaps_SG.3dm (351.6 KB)
it requires a bit of work, exploding splitting, making a helper surface etc. I can make a step by step if you like
Hi Steve - to keep the thing as all-fillets, Explode, Untriim these surfaces:
Then FilletSrf between those two surfaces, then trim, clean up and make good.
FilletEdge gaps_PG.3dm (282.0 KB)
