Steve1
October 29, 2026, 3:40pm
1
V5
Cannot get FilletEdge or FilletSrf to work.
FilletEdge almost does.
FilletSrf needs a few clicks, does a bit each time, some parts refuses to.
I want to get a soft up and over effect,
where the item was crimped over a spiral wire on an aerial, to stop movement fore/aft of the aerial cone.
what if I take the sphere along the rail, the edge of the ‘worm’
Perhaps I could get two rails and use a curve ?
how does one sweep an object along a path ?
Then draw a curve and sweep the intersection of it ?
FilletEdge or FilletSrfor sphere along a rail.3dm (2.0 MB)
Steve
Lagom
October 29, 2026, 5:39pm
2
Very odd. Here, with Rhino 8, it fillets with 0.3 just fine with FilletSrf .
Steve1
October 29, 2026, 7:45pm
3
Hi, just tried it in V8
set tolerance in units to 0.001 as has been observed elsewhere as had it 0.1
but no difference.
Used FilletEdge.
then tried FilletSrf
So why does my V8 do different to yours ?
then try rhino 9 set tol to 0.001 as told to do so.
get this.
Steve
Lagom
October 29, 2026, 7:50pm
4
As mentioned, I used FilletSrf . I opened your file and did not change the tolerances or anything else, for that matter.
Steve1
October 29, 2026, 7:58pm
5
Hi, what was tolerance, I am told to change it to,0.001.
In properties>units.
it was at 0.1
Steve
Lagom
October 29, 2026, 8:10pm
6
I downloaded your file, then opened it, then went straight to FilletSrf . Here’s what the file Settings… menu item brings up.
Steve1
October 29, 2026, 8:13pm
7
well thats what I am being told to avoid.
Tolerance mine was 0.1 and I am told to use 0.001.
Perplexed,
Confused.
@jeremy5
Steve
Lagom
October 29, 2026, 8:17pm
8
Here’s a video. Edges don’t matter. Fillets are transitional surfaces between pairs of other surfaces.
Lagom
October 29, 2026, 8:28pm
9
When I undo, lower the tolerance to 0,001 it works just as before.
Mind you, lowering the tolerance in the surface modelling process does not automagically re-create all prior surfaces with that new tolerance.
Tolerance lowered.3dm (3.2 MB)
