Fillet in Grasshopper
How can I fillet two intersecting circles with Grasshopper.
I cannot seem to find a component that is behaving the same like Rhino command. (input two curves and a radius)
Like this?
no, I don’t want to “merge” the two circles, imagine these are two crossing curves (disconnected) in Rhino with fillet you can create a fillet between them (join is optional). I’m surprised there’s no such component in GH after so many years of existence.
I ended up using ghpython as a workaround.
I also had to create additional points with CurveClosestPoint component and moving manually the points in order to get the filled I need. It’s terrible experience this way. Also, no parametric.
Same for Mirror, nothing in GH is useful (intuitive) and I used python
A better picture:
if I drag these points slightly the fillet will flip to the far side
Don’t worry, your precious circles are safe! :grinning:
fillet circles.gh (14.6 KB)
Not really using fillet there do you, that supports my point?
(post deleted by author)
