Fillet Edges & BlendEdges not working
Trying to !_FilletEdge or !_BlendEdge these edges, only 4-6mm or so… but i can’t get it to work!
I am pretty sure all edges are linked, there are a few NakedEdges that touch the edges that i am trying to Fillet/Blend but that’s not where the problem areas are. i have also tried to do them 1 by 1… Help please!
hard to judge from a screenshot
please post a .3dm file
the areas where filletedge fails to trim the new surfaces are suspects…
check with
_showEdges
_edgeContinuity
also check the overall precision
(what → Edge Tolerance)
hopefully you did not use _joinEdge with adapted tolerance…
and as written at top - post a file to get more feedback
(EDIT:)
a841e88bc8f5cb035bfd66f6ea42d6abd8bbf435
those 2 red edges might be a problem - not allowing a nice corner
workarounds might be:
(1)
fillet the blue edges first (with a bigger radius)
fillet the green edges second (with a smaller radius)
(2)
fillet with a smaller radius that will allow a nice corner
(3)
build the surrounding extrusion as a single surface.
_useExtrusions → Polysurfaces
_extrudeCrv → split at Tangents (Off)
… this is all i can get from the screenshots…
see also here
