Fillet Edge
Hello everyone,
I am trying to fillet a edge of my solid but even if it select it as the edge i would like to fillet it keeps giving me the same result… and besides that, how could I use different radius to the same fillet edge as it is possible in rhino?
Thanks in advance!
FILLET SOLID.gh (7.6 KB)
Hi!
Fillet Edge “Edge” input needs an integer, you are connecting a curve (which is converted to 0 or 1 …) , that’s your problem.
Use directly your slider value (an integer) to the “Edge” input and it will work as intended.
About variable filled (you meant that?), see here: Variable fillet in GH?
Ohh, didn’t know this! Thanks man!
yes i mean that, but the solution is too complex =(
If you want to control just the start and end radius of the fillets, you can do it with a script.
If you want 3 or more radii per edge, you need to use rhino, then.
