I would like to perform a blend edge, for example of 1, along the edges red, but Rhino 5 fails to perform well the intersections of the fitting.
In Rhino 6 this kind of situation will find a resolution automatically, or should always do everything manually?
Fillet edge problem.3dm (226.4 KB)
Thank you.
My guess is that this situation- where there is not enough space to fit both fillets at the specified radius, will not work in V6 either. What would be the desired result here, just trim the fillets to one another?
Thanks Pascal, maybe I’m wrong example … sorry
