Filled Regions created by RiR not adjustable vie grips
I created a bunch of filled regions via script, but when I try and adjust them via grip after being unpinned I get this error. Is this a glitch with RiR? Is there something I can do to fix it. As it is, if I edit the sketch, move the lines, and then hit ok, the Revit recognizes the filled region and I can adjust the grips. However, I have a lot of swatches to go through, and it is not reasonable to go through each one individually.
Hi @Liam4,
There is a problem that will be fixed on the next SR.
Meanwhile you can change the conponent Tracking Mode to Recreate instead of Update.
What is SR?
Hi Liam, Keep an eye on the release notes.
https://www.rhino3d.com/inside/revit/1.0/reference/release-notes
