Create a filled region and change its color with Rhino Inside
Hi. My goal is to create a filled region at the center of a bunch of doors and have each region display a unique color based on the door type.
So far I’m stuck on getting the filled region to create. Any advice? I’ve tried some of the other “filled region creation” threads but can’t piece together the workflow.
Thanks,
~Michael
Hi Frederick, This will get you started.
Note that I am getting all door types, you’ll want to make sure your list matches the ones you have in View.
Also ensure you are on a recent Rhino.inside.Revit build, there was a small color casting change recently.
re_Filled_Regions.gh (14.1 KB)
Thanks @Japhy. This was a big help. Unfortunately the color isn’t working for me.
color door dots 5.gh (34.2 KB)
I included version info in the screenshot if it helps.
Any ideas?
~Thanks
That looks to be the color casting to parameter.
You’ll need to update your RiR. The stable is 1.12 now, try that and then move up the RC.
