Hello all,
I have a question for you. I would like to fill the cavity automatically to a whole solid. You could imagine that the walls, floor, ceiling has been created to a closed solid.
Is there a Rhino command for this?
Thanks a lot
Hello all,
Thanks a lot
I guess these are (Void Solids) which are technically individual solids inside one big solid.
are you trying to combine them? What is your goal? calculating fill material volume?
My goal is to create the visible space on the image as a waterproof solid (Not a mesh). It is actually the opposite in the picture. The negative image. I need the object to create more parts from it. I donât want to spend hours splitting and welding each surface etcâŚ
Is there a Rhino command for this? or a work step?
Iâm not sure what you want @Boris_87 but considering that the elements donât touch, you may need to play with
1 - nonmanifoldmerge ( this will define a single part from volumes that are separated)
2 - createregions ( it will create the âsolidâ you want with the internal holes)
I hope this help,
JoaquĂn
Thank you very much for your help.
Imagine making a hole at the top of the outer shell and filling it with concrete. Then there would be a negative image of all the objects that are inside. Thatâs what I need.
I think I understand, did you try what I suggested? what did you get?
Uploading your file and attempts would be ideal for a better solution.
It could be that my commands are a bit different in Rhino, since Rhino is set to German⌠The first point has created a surface composite with my inner objects. The second one did not workâŚ
I have attached the test file⌠Maybe someone would like to open it and get smarter (I think I would be faster if I did it the old school way⌠)
Thanks for your help
TEST.3dm (307.2 KB)
Take a look at the model, if you see the image you can see how it looks with a clipping plane.
_CreateRegions should work if you type it in the command line.
TEST_JL_220530.3dm (303.4 KB)
Thank you for your it worked⌠But when I divide the model or disassemble it, it is again individual partsâŚ
âsolidsâ arenât really solid, they are only the boundary surfaces. For the purposes of rendering something like water, the pieces donât actually have to be a single object or even be closed, their normals just have to be pointing the right ways to get the right effect. You canât flip the normals on a closed solid, but you can on a mesh, so extracting a mesh to render would be recommended here
I see that I want something that is not CAD or technically possible. I need closed solids. I will model the negative Manuel. That is not a problem. Maybe that will come at a later date.
Thanks again for your help.
Many greetings
Boris
What are you actually trying to do? What is the end goal? What is the purpose of the model? Thereâs simply no such thing as âfillingâ a solid, thatâs not how it works, but itâs hardly a problem, depending on what you are actually trying to do wit this?
Hi Jim, itâs about complex architectural structures of existing buildings (laser scanning) easier to model + convert and deform to BIM objects. The whole thing would have been simple, a bit easier. Thatâs why I canât work with meshes etc. e.g. for walls there I model cubic, etcâŚ
Many greetings
Boris
