Very happy in Rh8 to find that exporting multiple layouts using “save as” now works.
This could save me lot of time if I could export multiple layouts to SVGs instead of one at a time.
I want the file names to be only the name of each layout (ie not with a base file name and a sequential tag).
This functionality is only available for PDFs, and even then it doesn’t quite work.
The first step in a Save As is to specify a file name, and you can’t leave it blank. When you check only the “add page name” box in the Rhino Save As dialog, it will still use that initial file name and an underscore before the layout name.
So, I just want to make sure there isn’t something I’m missing that would:
make the “add page name” function available for SVGs.
make it possible to export those layouts (aka pages) with just the layout name.
Thanks.
“save as” system dialog
Rhino “save as” panel with multiples options
result in windows finder
