It’s good that when we now got to print a layout page to pdf it respects the layout page name and names it as so, but, this only works when printing a single layout page. When you select Print Multiple Layouts it all goes wrong again. This should print out the layouts and keep the layout name as the file exported. This is critical when following naming conventions for architectural projects and the like. Please can we get this to work as it should🙏🏽
You should be able to select Add page name to filename as seen in my image. If your Rhino 8 is missing this option then please make sure you’re downloading and installing service releases.
yes thanks @Trav , this now finally works as it should have always worked, lots of publishing sheets to file all nicely named as the layout page
