That for me is too much clutter and might get in the way of conversations.
The current implementation by McNeel makes it possible to have a file inserted as a part of regular text.
like so:
I prefer the first because of the small footprint on screen. The report of size and, number of clicks could be a popup on mouse-over or something alike.
Or if you insist it could be by a click on a accompanying icon in front to the link like so:
For us the main reason is that we need to offer a system that is not dependant on other third parties. Filepicker if very mature and I doubt we will match it feature for feature for a very long time.
However, we still want to offer something complete / simple and streamlined for forums that need upload support and not force them to go elsewhere, it also simplifies the backup story among other things.
He probably meant S3 actually - that’s where we’re putting our files from Filepicker.io. If the Discourse uploader goes to S3, too, then Wim will likely be out of luck.
We’re using your file uploader now with the latest server upgrade. One thing we are noticing is that the downloaded 3dm files are being saved with the long unique amazon s3 name instead of the original filename.
On this discussion: Best approach to creating Wing Solids & Molds? Help Required! I can see the picture that Brian James uploaded and I can download the attached Wing.3dm file (from behind the corporate firewall). It’s this “sometimes I can, sometimes I can’t” that I’m not getting…
We recently changed how file/image attachments work. For a while, all of the files and images were going through an address that started with “filepicker.io”. The new images/attachments are located at amazonaws.com as Brian mentioned. I believe your corporate firewall is set to block content from filepicker.io, but possibly not from amazonaws.com
I didn’t read into his message that @wim is specifically writing about posts in that single topic. It sounds like everything in that specific thread works and it is probably because all of the links go through amazonaws.com
I think that might be correct, yes (and it would be nice).
I will be working from home or not working at all for some time to come but I’ll keep an eye on this and try to figure out what exactly is happening.
Thanks!
