Is it possible to have the objects description window placed in the left side of the interface such that it’s seperate from the objects properties panel. I always have to close “basic, display, and material” to get a look at the info I want.
you can use the command _Properties to float that panel and place it where you’d like… or the command _What will show only the info i think you’re after.
(not exactly what you’re wanting… but maybe it will do the trick)
