Feature request - osnap to any visible isocurve
With ExtractIsocurve, one can snap to any visible isocurve in the U or V direction. With SplitEdge no such snapping is available.
I would like to see SplitEdge allowing the same osnapping as ExtractIsocurve does, see below.
ExtractIsocurve allows you to freely choose, or snap to visible isocurves, as shown above. I never needed the Extract All option.
Understand. I’m going to delete my posts since they may be confusing to others.
Also, when creating curves, osnapping to any visible isocurve would be a boon.
Can you explain the purpose of splitting edges at isocurve positions?
Also here it would be good to show why you need this. We have to look into adding more snapping carefully as it might mess up other workflows.
Many such cases as below. In Alias or Catia, any visible isocurve can be snapped to at the edge of the surface boundary or anywhere in between, also matched to. ExtractIsocurve can snap to any visible isocurve in the U or V direction, so the snapping is already there ā€œunder the hoodā€.
Good morning @Gijs here’s another typical example (three-sided end of a ā€œsoftā€ shape) of why osnapping to isocurves, like the ExtractIsocurve tool already can, is useful. And another li’l thing regarding boundary curve detection ; )
there are two old requests for this:
RH-2916 Int for isocurves
RH-2444 Near Snap to isocurves on a surface
and also for blendcrv there is:
RH-73364 Isocurve detection during BlendCrv
I added this thread
I assume you want/need to snap to the end of the isocurve because it is the dividing curve between spans of a multi-span surface. In that case you can use the Knot Osnap to snap along the edges at the divisions between spans of multi-span surfaces. Knots are located at the divisions between spans of multi-span surfaces.
It’s just a visual isocurve of a single span surface. You can’t osnap to those - except with the ExtractIsocurve tool.
